  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the maximum EAP requests sent to the supplicant before timing out the session:
    eapol [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] max-request <1-10>
  3. Configure the time interval between authentication failure and the start of a new authentication:
    eapol [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] quiet-interval <1-65535>
  4. Enable reauthentication:
    eapol [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] re-authentication enable
  5. Configure the time interval between successive authentications:
    eapol [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] re-authentication-period <0, 60-65535>
  6. Configure the EAP authentication status:
    eapol [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] status {authorized|auto}
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface GigabitEthernet 1/2
Switch:1(config-if)#eapol max-request 10
Switch:1(config-if)#eapol port 1/2 quiet-interval 500
The following table defines parameters for the eapol port command.
Variable
Value
Specifies the port or list of ports used by EAP.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
max-request <1-10>
Specifies the maximum EAP requests sent to the supplicant before timing out the session. The default is 2.
Specifies the time interval in seconds between the authentication failure and start of a new authentication. The default is 60.
Enables reauthentication of an existing supplicant at a specified time interval.
Specifies the time interval, in seconds, between successive authentication. Configure the value to 0 to prevent EAP or NEAP sessions from aging out.
Caution: Preventing re-authentication can introduce a security risk.
The default is 3600 (1 hour).
Specifies the desired EAP authentication status for this port.
